channel.channelNumber |
Indicates the logical channel number that this Channel object is associated with when the Channel object Present_Value is written to using the WriteGroup service.
Property channelNumber of object channel can be read and written using a single IOTag.
channel-<objectAddress>.channelNumber |
<type> = 53 |
<property> = 366 |
A 16-bit integer value ranging from 0 to 65535.
