bitstringValue.relinquishDefault |
The default value to be used for the presentValue property when all command priority values in the priorityArray property have a NULL value.
Property relinquishDefault of object bitstringValue can be read and written using a single IOTag.
bitstringValue-<objectAddress>.relinquishDefault |
<type> = 39 |
<property> = 104 |
A string value representing a sequence of bits, where each bit is represented by the character '0' or '1' (ex: '01101010').
