bitstringValue.bitMask |
The pBitMask parameter of the object's event algorithm.
Property bitMask of object bitstringValue can be read and written using a single IOTag.
bitstringValue-<objectAddress>.bitMask |
<type> = 39 |
<property> = 342 |
A string value representing a sequence of bits, where each bit is represented by the character '0' or '1' (ex: '01101010').
