binaryValue.minimumOffTime |
Represents the minimum number of seconds that the presentValue shall remain in the INACTIVE state after a write to the presentValue property causes that property to assume the INACTIVE state.
Property minimumOffTime of object binaryValue can be read and written using a single IOTag.
binaryValue-<objectAddress>.minimumOffTime |
<type> = 5 |
<property> = 66 |
A 32-bit unsigned integer.
