binaryValue.alarmValue |
Specifies the value that the presentValue must have before an event is generated. Use 0 for inactive and 1 for active.
Property alarmValue of object binaryValue can be read and written using a single IOTag.
binaryValue-<objectAddress>.alarmValue |
<type> = 5 |
<property> = 6 |
An integer representing one of the options of enumeration <BACnetBinaryPV>.
