binaryOutput.timeDelayNormal |
Contains the pTimeDelayNormal parameter for the object's event algorithm.
Property timeDelayNormal of object binaryOutput can be read and written using a single IOTag.
binaryOutput-<objectAddress>.timeDelayNormal |
<type> = 4 |
<property> = 356 |
A 32-bit unsigned integer.
