binaryOutput.relinquishDefault |
The default value to be used for the presentValue property when all command priority values in the priorityArray property have a NULL value.
Property relinquishDefault of object binaryOutput can be read and written using a single IOTag.
binaryOutput-<objectAddress>.relinquishDefault |
<type> = 4 |
<property> = 104 |
An integer representing one of the options of enumeration <BACnetBinaryPV>.
