binaryOutput.polarity |
Indicates the relationship between the physical state of the Input and logical state represented by the Present_Value property. Use 0 for normal polarity, 1 for reverse.
Property polarity of object binaryOutput can be read and written using a single IOTag.
binaryOutput-<objectAddress>.polarity |
<type> = 4 |
<property> = 84 |
An integer representing one of the options of enumeration <BACnetPolarity>.
