binaryOutput.minimumOnTime |
Represents the minimum number of seconds that the presentValue shall remain in the ACTIVE state after a write to the presentValue property causes that property to assume the ACTIVE state.
Property minimumOnTime of object binaryOutput can be read and written using a single IOTag.
binaryOutput-<objectAddress>.minimumOnTime |
<type> = 4 |
<property> = 67 |
A 32-bit unsigned integer.
