binaryOutput.changeOfStateCount |
Represents the number of times that the presentValue property has changed state since the changeOfStateCount property was most recently set to a zero value.
Property changeOfStateCount of object binaryOutput can be read and written using a single IOTag.
binaryOutput-<objectAddress>.changeOfStateCount |
<type> = 4 |
<property> = 15 |
A 32-bit unsigned integer.
