binaryLightingOutput.strikeCount |
Represents the number of times that the Present_Value property or Feedback_Value property has transitioned from OFF to ON since the date and time indicated by the Time_Of_Strike_Count_Reset property. Whether Present_Value or Feedback_Value is used as the indicator for the calculation of the Strike_Count is a local matter. When this property is set to zero, the Time_Of_Strike_Count_Reset property shall be set to the current date and time. When this property is set to a non-zero value, the value of the Time_Of_Strike_Count_Reset property shall not change. If this property is writable, it shall be a local matter whether the property accepts writes of zero only. The Strike_Count property shall have a range of 0-65535 or greater.
Property strikeCount of object binaryLightingOutput can be read and written using a single IOTag.
binaryLightingOutput-<objectAddress>.strikeCount |
<type> = 55 |
<property> = 391 |
A 32-bit unsigned integer.
