binaryLightingOutput.egressActive |
Shall be TRUE whenever the Egress_Time for a WARN_RELINQUISH or WARN_OFF lighting operation is in effect and FALSE otherwise.
Property egressActive of object binaryLightingOutput can be read and written using a single IOTag.
binaryLightingOutput-<objectAddress>.egressActive |
<type> = 55 |
<property> = 386 |
