binaryInput.elapsedActiveTime |
Represents the accumulated number of seconds that the presentValue property has had the value ACTIVE since the elapsedActiveTime property was most recently set to a zero value.
Property elapsedActiveTime of object binaryInput can be read and written using a single IOTag.
binaryInput-<objectAddress>.elapsedActiveTime |
<type> = 3 |
<property> = 33 |
A 32-bit unsigned integer.
