binaryInput.deviceType |
String describing the physical device connected to the analog input. It will typically be used to describe the type of sensor attached to the analog input.
Property deviceType of object binaryInput can be read and written using a single IOTag.
binaryInput-<objectAddress>.deviceType |
<type> = 3 |
<property> = 31 |
A string value.
