binaryInput.alarmValue |
Specifies the value that the presentValue must have before an event is generated. Use 0 for inactive and 1 for active.
Property alarmValue of object binaryInput can be read and written using a single IOTag.
binaryInput-<objectAddress>.alarmValue |
<type> = 3 |
<property> = 6 |
An integer representing one of the options of enumeration <BACnetBinaryPV>.
