averaging.windowInterval |
Indicates the period of time in seconds over which the minimum, maximum and average values are calculated.
Property windowInterval of object averaging can be read and written using a single IOTag.
averaging-<objectAddress>.windowInterval |
<type> = 18 |
<property> = 147 |
A 32-bit unsigned integer.
