analogOutput.lowLimit |
Specifies a limit that the presentValue must fall below before an event is generated.
Property lowLimit of object analogOutput can be read and written using a single IOTag.
analogOutput-<objectAddress>.lowLimit |
<type> = 1 |
<property> = 59 |
A 32-bit floating point number.
