analogOutput.interfaceValue
Indicates the value, in engineering units, of the physical input. If the BACnet device is not capable of knowing the value of the physical input, then the value of this property shall be NULL.
Property interfaceValue of object analogOutput can be read and written using a single IOTag.
Text Parameters
Property
Value
ParamDevice
<deviceAddress>
ParamItem
analogOutput-<objectAddress>.interfaceValue
Numeric Parameters
Property
Value
N1:
<deviceAddress>
N2:
<type> = 1
N3:
<objectAddress>
N4:
<property> = 387
Tag Value
•A null/empty value.
•A 32-bit floating point number.
