analogInput.minPresValue |
Indicates the lowest number in engineering units that can be reliably obtained for the presentValue property of this object.
Property minPresValue of object analogInput can be read and written using a single IOTag.
analogInput-<objectAddress>.minPresValue |
<type> = 0 |
<property> = 69 |
A 32-bit floating point number.
