analogInput.limitEnable |
Conveys two flags that separately enable and disable reporting of highLimit and lowLimit offnormal events and their return to normal.
Property limitEnable of object analogInput can be read and written using a block tag with 2 elements.
analogInput-<objectAddress>.limitEnable |
Size |
2 elements |
B1: |
B2: |
<type> = 0 |
B3: |
B4: |
<property> = 52 |
2 elements |
Index |
Name |
Type |
0 |
lowLimitEnable |
1 |
highLimitEnable |
