analogInput.highLimit |
Specifies a limit that the presentValue must exceed before an event is generated.
Property highLimit of object analogInput can be read and written using a single IOTag.
analogInput-<objectAddress>.highLimit |
<type> = 0 |
<property> = 45 |
A 32-bit floating point number.
