analogInput.faultLowLimit |
Specifies a limit that the Present_Value must fall below before a fault event is generated by the FAULT_OUT_OF_RANGE fault algorithm.
Property faultLowLimit of object analogInput can be read and written using a single IOTag.
analogInput-<objectAddress>.faultLowLimit |
<type> = 0 |
<property> = 389 |
A 32-bit floating point number.
