analogInput.covIncrement |
Specifies the minimum change in presentValue that will cause a COVNotification to be issued to subscriber COV-clients. This property is required if COV reporting is supported by this object.
Property covIncrement of object analogInput can be read and written using a single IOTag.
analogInput-<objectAddress>.covIncrement |
<type> = 0 |
<property> = 22 |
A 32-bit floating point number.
