alertEnrollment.presentValue |
Indicates the current value of the object.
Property presentValue of object alertEnrollment can be read and written using a single IOTag.
alertEnrollment-<objectAddress>.presentValue |
<type> = 52 |
<property> = 85 |
A string value containing a BACnet Object Identifier in the syntax '<Type>-<Address>' (ex: 'analogOutput-345').
