accumulator.valueSet |
Indicates the value of the presentValue property after the most recent write to the valueSet or valueBeforeChange properties.
Property valueSet of object accumulator can be read and written using a single IOTag.
accumulator-<objectAddress>.valueSet |
<type> = 23 |
<property> = 191 |
A 32-bit unsigned integer.
