accumulator.scale
accumulator.scale
Indicates the conversion factor to be multiplied with the value of the Present_Value property to provide a value in the units indicated by Units.
Property scale of object accumulator can be read and written using a single IOTag.
Text Parameters
Property
Value
ParamDevice
<deviceAddress>
ParamItem
accumulator-<objectAddress>.scale
Numeric Parameters
Property
Value
N1:
<deviceAddress>
N2:
<type> = 23
N3:
<objectAddress>
N4:
<property> = 187
Tag Value
•A 32-bit floating point number.
•A 32-bit signed integer.
