accumulator.lowLimit |
Specifies a limit that the presentValue must fall below before an event is generated.
Property lowLimit of object accumulator can be read and written using a single IOTag.
accumulator-<objectAddress>.lowLimit |
<type> = 23 |
<property> = 59 |
A 32-bit unsigned integer.
