accumulator.loggingObject |
Indicates the objeto in the same device as the Accumulator object which, when it acquires loggingRecord data from the Accumulator object, shall cause the Accumulator object to acquire, present and store the data from the underlying system.
Property loggingObject of object accumulator can be read and written using a single IOTag.
accumulator-<objectAddress>.loggingObject |
<type> = 23 |
<property> = 183 |
A string value containing a BACnet Object Identifier in the syntax '<Type>-<Address>' (ex: 'analogOutput-345').
