accumulator.limitMonitoringInterval |
Specifies the monitoring period in seconds for determining the value of PulseRate.
Property limitMonitoringInterval of object accumulator can be read and written using a single IOTag.
accumulator-<objectAddress>.limitMonitoringInterval |
<type> = 23 |
<property> = 182 |
A 32-bit unsigned integer.
