accumulator.deviceType
String describing the physical device connected to the analog input. It will typically be used to describe the type of sensor attached to the analog input.
Property deviceType of object accumulator can be read and written using a single IOTag.
Text Parameters
Property
Value
ParamDevice
<deviceAddress>
ParamItem
accumulator-<objectAddress>.deviceType
Numeric Parameters
Property
Value
N1:
<deviceAddress>
N2:
<type> = 23
N3:
<objectAddress>
N4:
<property> = 31
Tag Value
A string value.
