accessZone.passbackMode |
Specifies how all Access Point objects that represent entry points to the access controlled zone this object represents shall handle passback violations.
Property passbackMode of object accessZone can be read and written using a single IOTag.
accessZone-<objectAddress>.passbackMode |
<type> = 36 |
<property> = 300 |
An integer representing one of the options of enumeration <BACnetAccessPassbackMode>.
