accessZone.occupancyUpperLimit |
Specifies the occupancy upper limit of the zone. If this property has a value of zero, then there is no upper limit. If this value is not zero, it shall be greater than the value of the Occupancy_Lower_Limit, if present.
Property occupancyUpperLimit of object accessZone can be read and written using a single IOTag.
accessZone-<objectAddress>.occupancyUpperLimit |
<type> = 36 |
<property> = 297 |
A 32-bit unsigned integer.
