accessZone.occupancyLowerLimit |
Specifies the occupancy lower limit of the zone. If this property has a value of zero, then there is no lower limit.
Property occupancyLowerLimit of object accessZone can be read and written using a single IOTag.
accessZone-<objectAddress>.occupancyLowerLimit |
<type> = 36 |
<property> = 294 |
A 32-bit unsigned integer.
