accessZone.occupancyCountEnable |
Indicates whether occupancy counting is enabled (TRUE) or not (FALSE). If this property has a value of FALSE, then the Occupancy_State property shall have a value of DISABLED. When this property changes from FALSE to TRUE it is a local matter as to what value the Occupancy_Count property is set to.
Property occupancyCountEnable of object accessZone can be read and written using a single IOTag.
accessZone-<objectAddress>.occupancyCountEnable |
<type> = 36 |
<property> = 292 |
