accessZone.occupancyCount |
Used to indicate the actual occupancy count of a zone. If the value of the Occupancy_Count_Enable property is FALSE, then this property shall have a value of zero. The value of the Occupancy_Count property may be adjusted by writing to the Adjust_Value property. The Occupancy_Count property shall be writable when Out_Of_Service is TRUE. When Out_Of_Service becomes FALSE, it is a local matter as to what value this property is set to.
Property occupancyCount of object accessZone can be read and written using a single IOTag.
accessZone-<objectAddress>.occupancyCount |
<type> = 36 |
<property> = 290 |
A 32-bit unsigned integer.
