accessUser.userExternalIdentifier |
Specifies an external identifier associated with the access user. While the content is typically unique, its interpretation is a local matter.
Property userExternalIdentifier of object accessUser can be read and written using a single IOTag.
accessUser-<objectAddress>.userExternalIdentifier |
<type> = 35 |
<property> = 310 |
A string value.
