accessRights.enable |
Indicates and controls whether (TRUE) or not (FALSE) logging of events is enabled. Logging occurs if and only if Enable is TRUE, Local_Time is on or after Start_Time, and Local_Time is before Stop_Time. If Start_Time contains an unspecified datetime, then it shall be considered equal to 'the start of time'. If Stop_Time contains an unspecified datetime, then it shall be considered equal to 'the end of time'. Log records of type log-status are recorded without regard to the value of the Enable property.
Property enable of object accessRights can be read and written using a single IOTag.
accessRights-<objectAddress>.enable |
<type> = 34 |
<property> = 133 |
