accessPoint.transactionNotificationClass |
Specifies the instance of the Notification Class object to use for event-notificationdistribution of Access Transaction Events. If this property is not present, then the Notification Class specified by the property Notification_Class shall be used for Access Transaction Events.
Property transactionNotificationClass of object accessPoint can be read and written using a single IOTag.
accessPoint-<objectAddress>.transactionNotificationClass |
<type> = 33 |
<property> = 309 |
A 32-bit unsigned integer.
