accessPoint.occupancyUpperLimitEnforced |
Indicates whether the upper occupancy limit of the access controlled zone, for which this object is an entry point, is enforced (TRUE) or not (FALSE). If enforced, authorization shall fail if the access controlled zone's occupancy is greater than or equal to its upper occupancy limit, unless the credential is exempted from this authorization check. When this authorization check fails, the Access_Event property shall be set to DENIED_UPPER_OCCUPANCY_LIMIT.
Property occupancyUpperLimitEnforced of object accessPoint can be read and written using a single IOTag.
accessPoint-<objectAddress>.occupancyUpperLimitEnforced |
<type> = 33 |
<property> = 298 |
