accessPoint.numberOfAuthenticationPolicies |
Specifies the number of specified authentication policies. This property shall always have a value greater than zero. If the value of this property is changed, the size of the Authentication_Policy_List array and the size of the Authentication_Policy_Names array, if present, shall also be changed to the same value.
Property numberOfAuthenticationPolicies of object accessPoint can be read and written using a single IOTag.
accessPoint-<objectAddress>.numberOfAuthenticationPolicies |
<type> = 33 |
<property> = 289 |
A 32-bit unsigned integer.
