accessPoint.musterPoint |
Indicates whether this Access Point generates muster access events (TRUE) or not (FALSE). A muster event is generated by setting the Access_Event property to MUSTER after an access credential has been presented at the access point. It is a local matter as to whether a muster event is generated for unknown credentials.
Property musterPoint of object accessPoint can be read and written using a single IOTag.
accessPoint-<objectAddress>.musterPoint |
<type> = 33 |
<property> = 287 |
