accessPoint.lockoutRelinquishTime |
Specifies the time, in seconds, to delay after the Lockout property has taken on the value TRUE, before automatically relinquishing the lockout state. The lockout state is relinquished by setting the Lockout property to FALSE. A value of zero indicates that the lockout state will not automatically be relinquished.
Property lockoutRelinquishTime of object accessPoint can be read and written using a single IOTag.
accessPoint-<objectAddress>.lockoutRelinquishTime |
<type> = 33 |
<property> = 283 |
A 32-bit unsigned integer.
