accessPoint.failedAttemptsTime |
Specifies the time, in seconds, to delay before setting the Failed_Attempts property to zero, after the last failed access attempt.
Property failedAttemptsTime of object accessPoint can be read and written using a single IOTag.
accessPoint-<objectAddress>.failedAttemptsTime |
<type> = 33 |
<property> = 274 |
A 32-bit unsigned integer.
