accessPoint.failedAttempts |
Indicates the current count of successive failed access attempts. Any successive failed access attempt shall increment the value of this property. This property shall be set to zero when a successful access attempt occurs or when the property Lockout becomes FALSE.
Property failedAttempts of object accessPoint can be read and written using a single IOTag.
accessPoint-<objectAddress>.failedAttempts |
<type> = 33 |
<property> = 273 |
A 32-bit unsigned integer.
