accessPoint.authorizationMode |
Determines how authorization is performed at the Access Point. An Access Point object is not required to support all of these authorization modes but is required to support at least AUTHORIZE.
Property authorizationMode of object accessPoint can be read and written using a single IOTag.
accessPoint-<objectAddress>.authorizationMode |
<type> = 33 |
<property> = 261 |
An integer representing one of the options of enumeration <BACnetAuthorizationMode>.
