accessPoint.activeAuthenticationPolicy |
Specifies the active authentication policy. The active authentication policy of this object shall be one of 'n' authentication policies, where 'n' is the number of authentication policies defined in the Number_Of_Authentication_Policies property.
Property activeAuthenticationPolicy of object accessPoint can be read and written using a single IOTag.
accessPoint-<objectAddress>.activeAuthenticationPolicy |
<type> = 33 |
<property> = 255 |
A 32-bit unsigned integer.
