accessPoint.accompanimentTime |
Specify the time, in seconds, to wait for a second credential to be presented at this access point when the original credential requires accompaniment. If an accompanying credential is not presented within this time the authorization of the original credential shall fail and the Access_Event property shall be set to DENIED_NO_ACCOMPANIMENT.
Property accompanimentTime of object accessPoint can be read and written using a single IOTag.
accessPoint-<objectAddress>.accompanimentTime |
<type> = 33 |
<property> = 253 |
A 32-bit unsigned integer.
