accessPoint.accessEventTime
Indicates the most recent update time of the Access_Event property. This property shall update its value on each update of Access_Event. Update times of type Time or Date shall have X'FF' in each octet, and Sequence Number update times shall have the value 0 if no update has yet occurred.
Property accessEventTime of object accessPoint can be read and written using a single IOTag.
Text Parameters
Property
Value
ParamDevice
<deviceAddress>
ParamItem
accessPoint-<objectAddress>.accessEventTime
Numeric Parameters
Property
Value
N1:
<deviceAddress>
N2:
<type> = 33
N3:
<objectAddress>
N4:
<property> = 250
Tag Value
A Date, Integer, Null or String (Xml) value representing a timestamp in BACnet.
•A null value means the timestamp is empty/not set;
•A date/time value representing a precise date and time;
•An integer defining the timestamp sequence number;
•A character string containing an XML with a value of type <BACnetTimeStamp>.
