accessPoint.accessEventAuthenticationFactor |
Specifies the authentication factor that corresponds to the access event specified in the Access_Event property, if applicable. Otherwise it shall contain a value of format type UNDEFINED.
Property accessEventAuthenticationFactor of object accessPoint can be read and written using a block tag with 3 elements.
accessPoint-<objectAddress>.accessEventAuthenticationFactor |
Size |
3 elements |
B1: |
B2: |
<type> = 33 |
B3: |
B4: |
<property> = 248 |
3 elements |
Index |
Name |
Type |
0 |
FormatType |
An integer representing one of the options of enumeration <BACnetAuthenticationFactorType>. |
1 |
FormatClass |
A 32-bit unsigned integer. |
2 |
A string value representing a sequence of octets, where each octet is represented by a pair of hexadecimal characters (ex: '0F121A'). |
