accessPoint.accessEvent |
Indicates the last access event which occurred at this Access Point.
Property accessEvent of object accessPoint can be read and written using a single IOTag.
accessPoint-<objectAddress>.accessEvent |
<type> = 33 |
<property> = 247 |
An integer representing one of the options of enumeration <BACnetAccessEvent>.
